Avantis can connect with dLive - DM32?
Hi Everyone, Has someone ever tested Avantis connect with DM32. is that compatible and what any issue for that? and what is solution? Thank for your response.
TBH, we had a similar question on the weekend. So why not searching for an answer before posting?
And there are much more questions like this.
Thank you for response
Connecting an Avantis to a DLive Mixrack is just like connecting any two consoles together in A&H world. Each console will be completely independant from each other and each will control the I/O (preamp settings, etc) that is directly connected to the console. You can however pass/share I/O between the different systems however.
Specifically with an Avantis and a Dlive, you need to connect the systems together using a dedicated GigaAce connection. A GigaAce I/O card will be required to be installed on the DLive side of things for this connection. You can use the built in SLink port on the Avantis for this connection with the DLive, but if you are already using it to connect to a stagebox or other device, then a GigaAce I/O card would be required on the Avantis side as well.
Thanks for your response
