I need help with Avantis + Dante V3 + Dante Virtual Soundcard.
Actually, I have two problems with this setup, but to keep things separated, I’ll make one post per problem.
This problem is about using the A&H Dante V3 card in a proper network with DHCP assigned addresses.
I have reduced my setup to the simplest possible:
- A windows PC with Reaper, Dante Virtual Soundcard and Dante Controller
- Avantis (“duo”) with a 64x64 Dante V3 card in slot 2
- The PC is connected directly to the primary port on the Dante card. No switch in between and therefore no DHCP server on the “network”.
In this setup the Dante Controller finds the A&H Dante card as it should.
On the Avantis the card is listed as “Dante 64x64 V3 Version 2”.
However, I would like the Dante card and my PC to sit on a proper network with DHCP assigned IP addresses and in the future with more Dante devices.
If the A&H Dante card is connected to a switch on my network, it becomes invisible to Dante Controller. My PC is connected to the same switch and it gets a proper IP address from my DHPC server.
I can see in the DHCP server status that the Dante card requests an IP and it gets a proper one that fits in the network.
On the Avantis the card is listed as “Dante 64x64 V3 Version Unknown”. See screenshot #1.
Do you know what’s going on here?
As mentioned in my other post, I am struggling a lot with this Dante setup.
My Dante card was previously on firmware 1.0.1 and back then it was actually visible in Dante Controller with a DHCP assigned IP address next to my Dante Virtual Soundcard with the DHCP assigned address from my Windows PC.
Because I am struggling to solve the issue on my other post, I chose to upgrade the firmware. It went smoothless but now I have this issue.
There is no firmware 1.0.1 on the Allen & Heath website, so I can’t downgrade to that again.
Do you have any ideas how to fix this?
