I need help with Avantis + Dante V3 + Dante Virtual Soundcard.
Actually, I have two problems with this setup, but to keep things separated, I’ll make one post per problem.
This problem is about playing multitracks from a Windows PC via Dante back to Avantis (virtual soundcheck).
I can’t get ANY signal on the Avantis console.
Afte struggling for days, I have reduced my setup to the simplest possible:
- A windows PC with Reaper, Dante Virtual Soundcard and Dante Controller
- Avantis (“duo”) with a 64x64 Dante V3 card in slot 2
- The PC is connected directly to the primary port on the Dante card. No switch in between and therefore no DHCP server on the “network”.
Dante Controller finds both devices: The A&H Dante card and DVS, both with self-assigned IP addresses (APIPA). Both devices are set to 96k sample rate. See screenshot #1.
Routing in Dante controller is 1-1 from the PC (called TROMMERUM) as transmitter to A&H Dante as receiver. All channel subscriptions are green. See screenshot 2.
The A&H Dante card is clock leader.
So far so good.
Reaper is configured to use DVS ASIO device and my tracks are routed to Dante tx1, Dante tx2, etc. Unfortunately, I don’t have a screenshot of that right now.
Reaper selects 96k sample rate from the ASIO configuration.
On the Avantis console, I have patched I/O Port 2 ch1 to input ch36. See screenshot #3.
When playing the tracks in Reaper, I would expect signal on Avantis ch36, but it is completely dead.
The goal is to use the Virtual Soundcheck function in the Avantis console, so I have also patched 1-1 from I/O Port 2 ch1 to Avantis input ch1, I/O Port 2 ch2 to Avantis input ch2 etc. on the virtual soundcheck screen. Again, I don’t have a screenshot of that right now.
When activating virtual soundcheck, there is absolutely no signal on any of the 22 input channels that are played from Reaper.
What am I doing wrong here?
How do I determine whether this is a Reaper issue? A Dante network issue or an Avantis issue?
A Reaper issue?
In Reaper I have switched to another ASIO device (Motu) and set up equivalent routing. Tracks are playing fine with signal on the Motu. So I expect my Routing to be correct.
I have tried with Harrison LiveTrax as well. Importing my tracks, setting up to play on ASIO DVS. Everything seems fine, but absolutely no signal on the Avantis. That was my first experience with LiveTrax, so I may have missed something.
All in all, I don’t think Reaper is the issue here.
An Avantis issue?
I have tried switching Avantis’ audio sync from Internal to I/O Port 2. It didn’t help, so I switched back.
Avantis was on firmware 1.31 and I have upgraded to 1.32. It didn’t help.
The Dante V3 card was on firmware 1.01 and I have upgraded to 1.02. It didn’t help.
I don’t have any other Dante devices to test with.
A Dante network issue?
As far as I can tell, everything seems fine in Dante Controller.
As Avantis and the PC are on their own “dedicated network” by being directly connected by a single ethernet cable, no foreign devices or network traffic can interfere with the Dante traffic.
I don’t know how to troubleshoot further on this part of the setup.
Actually, my 22 tracks in Reaper were recorded from this console with this Dante card, so something must have been working. However, I was not the one doing the recording and it was done on another PC. The guy who did it is not available for the time being. The 22 tracks were recorded as tie lines from the stage inputs (S-Link) to the DVS on his PC.
To test further, I have a microphone plugged in to Avantis local input socket 1 and patched it to input ch49.
In the I/O screen I have set up a tie line from Avantis local input socket 1 (the microphone) to I/O Card 2 output ch1 (the Dante V3 card).
In Dante Controller I have routed A&H Dante output ch1 (transmitter) to DVS input ch1 (receiver).
In a Reaper session with one track, routed from Dante rx1 and armed, I do not see any signal at all.
Looking at Dante Controller’s device view, the small speaker icon lights up on A&H Dante transmit ch1, when I speak in the microphone. So the Dante network does actually see a signal from the Avantis.
In this scenario, I would also expect the small speaker icon on DVS input ch1 to light up, but it doesn’t. See screenshot #4.
My head is about to explode. I really can’t see, what I am doing wrong here.
I tried switching the DVS from ASIO to WDM. It only lets me use very few channels, but in this mode I actually got signal from the microhone on Avantis input socket 1 to Reaper! The audio had a lot of clicks and pops, bot audio was actually passing through the network.
So, are all my issues related to ASIO problems?
My PC is old and running Windows 7. That’s why DVS is version 4.3.1.1 (newer versions don’t support Windows 7).
I have tried on a newer PC running Windows 10 and the latest version of DVS, but I have exactly the same issues with that PC.
I really don’t know how to proceed.
Can you help me?
