Hi.
I’m running into a random/unpredictable issue with an Avantis/GX4816 system that was recently installed in a school theatre/auditorium.
The GX4816 is randomly disconnecting from the Avantis without warning. It was happening quite regularly shortly after the install last November. The install company advised re-pushing the firmware.
Things were going fine until this afternoon where this happened again.
Link is through a managed gigabit switch, all cabling is shielded Cat6a. Cable run is under 150’.
Anybody from A&H care to chime in and advise? Coming into busy season here and this issue is a show-stopper.
Hi guys,
Thanks for the input. I see there’s a new firmware update out today.
I’m going to push that and see if that makes things more stable. If the issue pops up again I’ll try a direct link, I’m going to have to build and run cable for that.
It’s a weird issue.
