So, I am looking into purchasing a Stream Deck for my productions. I recently have been thinking about buying a stream deck to call Qlab cues during productions. I am also thinking about using the Stream Deck to control the avantis softkeys. Does anyone know if you can program this to work?
I’m not sure if you can directly control softkeys, but you can control a large number of parameters from the streamdeck. I’d suggest that you download the companion software, and play around with it to see if it can do what you need before buying the streamdeck. You can do everything you’d need without the hardware, the hardware just provides a control surface.
You can ask the seller for help with this problem. I think that if they want to sell things, they will help you as much as they can.
