I have my config like my Avantis solo and a dante i/o card to a RME Digiface (4 RJ45 port) Dante linked into my pc. I use that for multi track recording and using Superrack Performer With waves plug in.
I would like to ad a DSP into dispo but i don’t no if i have a solution ?
I Know i can buy a i/o waves card and a DSP Serveur waves but i want to use this into my dante configuration. Any body have a solution or an idéa ?
I don’t understand what you are trying to do (and I’m probably not the only one). Can you please rephrase this and go into more detail about what you are trying to accomplish?
Hi,The “official” solution to ad a Waves server with the lowest latency in Dante world is the WSG Bridge with SuperRack SoundGrid.
But… if latency is a problem for you maybe Dante isn’t the right way.
For Waves plugins, Dante latency will be always superior to Waves solution.
If you select your plugins you can achieve a descent roundtrip latency with your RME and a software like Live Professor (I have rme too and RTL mesured with smaart is around 3-4 ms at 96 KHz with plugins who don’t ad latency).
Advantage is you can use plugins from others manufacturers.
Indeed, there are also these solutions that I had seen but forgotten about…
Without having more details, I was still thinking of making do with the equipment he already has.
Sure I think it’s the only solution if I want to do that in Dante but more expensive than the waves i/o card and a waves serveur so I think I have to buy the waves solution if I want a stable solution
If I understand correctly, you are already running plugins with the Dante system. With the Dante hardware on the computer side (RME DigiFace Dante), you should really be seeing pretty low roundtrip latency times. I would expect them to be in the 4-6ms range currently (total roundtrip time not including any plugin induced latency).
The Waves Soundgrid server system will absolutely provide lower latency (ie faster round trip times). With a Waves card and Soundgrid server setup, you should expect to see roundtrip latency times in the 2ms range (again, not including any plugin induced latency).
Whether or not it is worth the roughly $5000 (or more) that you are going to have to spend to purchase the Waves I/O card ($2800), Superrack Server (starts at $1300 and moves up quickly), and the Superrack software license ($600) to shave off 2-4ms in latency of your current setup is up to you.
Outside of the latency story, there will be little to no difference between running plugins through the Dante I/O card and running them through a Waves I/O card. So if you have a problem with something other than the latency times, switching to a Wave Soundgrid system probably won’t change it. There are other software solutions that you can try (Live Professor, various DAWs, etc) if you want to use something other than Waves Performer as your plugin host.
PS - I wouldn’t expect the Waves Dante Bridge or the Fourier Transform server to provide remarkably better latency times because they both still have to use the Dante network for audio transmission. I’ve checked and it seems the “best” latency times with the Fourier system is a 3ms roundtrip (but it can be higher). I would expect the Waves Dante Bridge to end up in the 4-6ms range as well because you are taking the roughly 2ms Waves Soundgrid system latency and adding the Dante network latency (1ms each way) along with some sort of conversion latency between the two systems (I’m guessing 1-2ms). That being said, I haven’t been able to find “real world” examples to back that up.
