I’ve got an Avantis Solo and sometimes when I am adjusting things for example the 76, I touched it to use the touch and turn know, the input jumped up about 40 and I thought that was weird but its starting to do it with any sort of threshold or touch and turn things. It’ll either skyrocket or nose dive when I tap it. Anyone else have this problem?
mine is smooth.. are you running the latest firmware?
Im on 2.0. I also have a problem where it always fails to shut down on the first try. It gives a screen didn’t shut down correctly error but then it’s fine. It’s just a couple weird things going on
That particular experience is a “known bug” listed in the firmware update notes. Hopefully they get it fixed, but that bug wouldn’t cause any of the other symptoms or experiences that you described.
