Hi everyone. I have a problem with this error. What can it be? Touchscreen works and there is no problem with touchscreen.
Same here. It shows the error at startup. Since the desk is brandnew I thought it was the screenprotector still attached, so I removed it and the error disappeared. But at the next startup the desk showed the error again. And disappeared again. The touchscreens works fine.
It shows not only at startup, Once at startup and may be one or two hour later. if I use long.
I do see this error a lot in my log file. It absolutely happens when the console is first booted, but it has been logged at other random times. However I have never noticed an issue with the touch screen during use and therefore I haven’t worried about these log entries nor entered a support ticket with A&H about them.
Mine stopped showing this error.
I guess I’ll file this behaviour under “character”, just like the error lights in the dash of my Alfa Romeo… ![]()
I too, had this error; and found that it was somehow in my show. When I changed to a different show, no error. Reload my show, the error appears. I had to start over and re-write my show. (I now save my show under a different name every week, just in case it happens again, so I don’t lose so much.)
