Hi!
I‘m wondering how i can backup / copy my scenes and channel settings from my SQ6 board to the USB stick?
On the stick there are folders named „scenes“ for example … so it must be possible? Or will this come with one of the next firmwares ?
Cheers from cologne,
Torsten ![]()
Actually you can only save a “Show” on USB stick.
Manual says :
“A ‘Show’ allows you to store all SQ settings and scenes at once, and is used to back-up the mixer settings, or transfer them to another SQ, using SQ-Drive.The show manager is located in the ‘Utility’ screen, in the ‘USB Data’ tab.”
Hello torstendrums,
Ditto on Flo84’s response.
Perhaps what you are looking for can easily be found by consulting the (RTFM) manual:
SQ Reference Guide V1.3.0
Page 51-52
11.4 Show manager (USB)
A ‘Show’ allows you to store all SQ settings and scenes at once, and is used to backup the mixer settings, or transfer them to another SQ, using SQ-Drive.The show manager is located in the ‘Utility’ screen, in the ‘USB Data’ tab
To store a show to a USB device:
• Touch the ‘Store New’ button - you will be prompted to name the show
To recall a show
• Touch a show to highlight it (use the touchscreen rotary to change selection orscroll through all shows) then touch the ‘Recall’ button.
To rename a scene:
• Touch a show, then touch in the ‘Name’ field in the centre of the screen.To overwrite a scene:
• Touch the scene to overwrite, then touch the ‘Overwrite’ button.
! Storing or recalling shows is not possible when SQ-Drive is being used for recording orplayback.
! Storing or recalling shows will interrupt USB-B streaming
If not I’ll be willing to bet it can be found / dispelled in A&H published literature or video elsewhere on the internet.
My search took me all of 15 seconds, considerably quicker than this post took…
Thanks! I was looking for saving several individual scenes but for backup it‘s ok with the shows i think. Thanks again for taking the time! ![]()
Quite welcome. Sorry I could not be of more definitive assistance. Best of luck.
