Bass compression on AUX channel
We have a compressor on the bass guitar channel which goes to the FOH sound system. We also send the bass signal to an AUX channel for broadcasting to our ISP. Can we have a separate/different compressor on our AUX channel going out to the broadcast? Does this require the changing of the AUX routing, i.e. pre/post?
User a second Input Channel to create an Independent Mix.
+1.
Route the bass guitar physical input to two (2) separate input strips.
You can then adjust each input strip as required.
Dave
