Hello,
I was reading section 4.1 of the manual and noticed that it said
"Mono Line Input – Balanced 1⁄4” TRS (Tip, Ring, Sleeve) jack input for plugging in line level signals such as multitrack players and radio mic receivers. To work with unbalanced sources use a mono jack or link ring to sleeve within the TRS stereo jack.
I find this wording to be confusing. Where are the mono jacks? Does the manual mean the ST1 or ST2 inputs? If so, which of the 32 channels do these override?
Is this for live use or recording?
If it’s live as in on stage use a DI box with a mic line back to the
mixer.
If it’s a recording set up and your setting at the mixer as you play and
record you could plug directly into a 1/4 input with a standard guitar cord.
If your guitars have active pre-amps in them would work best in that setup, if
they are fully passive pick up guitars (no batteries) your better off going
through a DI box and then into the boards mic inputs.
