better documentation
for a brand new user i found the documentation to be nice but inadequate
terms used were not defined or not defined until long after there first use
i see comments in the forums that tell things that are not in the users manual for the qu32
suggest adding a glossary of all acronyms and terms used
also adding all the missing tips and factoids found in these discussions here
as to videos
there are many of them
most are poor to bad or worse
and most have terrible audio that is not intelligible. often too low, or noisy ,
or worse also has useless noise andor ‘music’ that destroys the words so they cant be understood
and many have bad camera usage, others go way too fast with a sudden arm in front of the camera
AH should make high quality documentation and videos not rely on others to provide good training as that is a fail
What are some of the terms you were expecting to have defined?
A&H has a number of videos related to the Qu series on their YouTube channel: https://www.youtube.com/user/AllenandHeathUK/playlists
@Ryan
I would like the manual to have a list of all the acronyms and abbrevs in a list for reference.
Some can be figured out. Some remain a mystery until you stumble upon the answer.
Also explain AH usage which I find in cases to be different from the way I had seen it used in the past.
Finally, I am discovering that the manual does not cover all the details that could be useful.
At a minimum it should show an org chart of all the screens to guide understanding and for reference by new users.
