Better ganging (relative/absolute options)
please just more ganging options.
at the moment if you gang channels, it basically copies all the settings from the first channel into the next one (absolute)
with relative ganging you could, for instance, gang your gates for the toms without affecting the treshold or depth of each gate.
e.g.:
  • when turning the treshold rotary on one tom, it will change the treshold of all the toms relatively to the previous setting
  • for this one quiet part of the set you can just turn all the gates on the toms on/off while still keeping all the relative settings for each tom
I’m absolutely agree with that !!!
The relative option will be amazing !!
With an “on/off” to easily switch between ganged or not. We can make a temporary correction and easily return to a channel.
+1
Please also output ganging would be a big Thing!
why do you need output ganging?
Hi Steffen,
I realized now, that I can use dca’s to gang output faders.
That’s my need - to control Aux and Mtx Faders at once.
But on the dlive it’s possible to gang Outputs - isn’t?
Maybe there’s also once a situation where the ganging of the processing in Auxes is needed?
Monitoring?
But I understand that the little Brother of the dlive won’t have all the same specs :wink:
Greetings
But I understand that the little Brother of the dlive won’t have all the same specs ?
the SQ is not the little brother
it’s different
the Avantis is more the little brother
Shure - maybe it’s more the little, little 15 years younger sister :wink:
