when using a windows computer, we always get error 512 or error 1024 when powering up the dante virtual soundcard.
We have tried defferent machines with windows 7 (32 bits and 64), different versions (home,ultimate) and also windows xp/32. on every machine the same thing.
When connecting anything directly point to point gld to computer, in some times it works. if not, disconnecting the lan cable often helps, on other times rebooting the dante brooklyn module in the mixer via the dante controller helps.
the audinate support suggested me to install itunes insted of bonjour for windows, because bonjour included in itunes is more up to date than the standalone version. no change of issues.
connecting the 2 devices wia our local network in our company (there are some pc’s and a switch) it works better than direct, but also not free of issues (same problems, but not so often).
last time i tried an apple computer, everything works fine and perfect all the time at the first attempt.
Last time i tried to do a multitrackrecording with win7 again - after the normal problems with errors 512 and 1024 the virtual soundcard works (at this time). after doing all routing in dante contoller we started recording with cubase. During the show we saw, that nothing was recorded this time - empty tracks.
2 hours before we tested it, we got a signal on every track…
someone has the same problems? solutions?
