Blocking all Mixes call-up except LR in Standard and Basic
Hi all,
Re: QU-16 Functionality.
In our Church we use the Alt out to feed ST2 IN via a patch cable (no Matrix in this model)
Then the Mixes are ALL assigned to different speaker locations.
ex: Mix 1 fees vestibule Mix 7&8 feeds wings mix 4 feeds outdoors etc…
The LR mix (Master Fader)feeds the large FOH speakers and its alt out then feeds all the others.
On all those other mixes the ONLY fader up is the Stereo 2 fader.
But magic fingers adjust other faders in those mixes screwing up the whole plan.
I ONLY want the ADMIN to be able to adjust those mixes.
So I want all the MIX buttons on the iPad right to be non functional in “Standard” and “Basic” (only LR to be active
Also the MIX button far left should not display the mix faders but ONLY in ADMIN mode.
Thanks, Jay
Funkymusic2k@gmail.com
Is this at all do-able
In the user set up for the standard level you can set what level of access the user has.
The basic user level only has access to the LR main mix and mutes.
In addition you could set up custom layer access only mode and in the custom layer only include the channels needed for standard and basic operation.
You do want to make sure that the ST2 channel is un-assigned from the main LR mix as a safety measure!
The mix buttons on the iPad app will still display only be non functional.
