Bluetooth start up issue
I am now starting to think, that when the CQ12T is powered on, with nothing inserted (Card, stick, USB B) the Bluetooth initialises fine, but with something inserted while powering up, the Bluetooth ‘initialises’ forever. Most probably only the screen, because it looks like that known devices still connect fine via Bluetooth.
Hmm… It’s a mess. USB is also involved in the problem. I think A&H should devote some serious TLC , checking out the variety of start up / shut downn (?) with card, stick, USB possibilty’s. Right now is almost an unusable situation…. Too unpredictable what is going to work , and what not, after starting up
my unit is doing this randomly. wifi and bluetooth just say ‘initializing’ after boot up, nothing fixes it except a shutdown and restart. I’ve re-flashed the firmware and done a factory reset. I have an SD card in it at all times, I haven’t experimented without the card in it, will try that.
The service of A&H is world class. They noticed me, that the problem is recognised, and that a fix is in the making. Thank you so much ?
Really? I’m looking forward to the fix. I did some testing, and it doesn’t matter if I have USB or SD cards plugged in, the unit will still do it (network and bluetooth stuck on initialising). A shutdown and restart usually fixes it. Assume this will come in an FW update. cheers
The same thing happens to me, were you able to solve it? Thanks
I had my unit completely replaced. I sent it to the distributer, they provided a new one. The new one doesn’t have the fault
Does anyone know if there is a fix for this continual ‘initialising’?
Mine started this 2 months ago and new devices (mainly phones for music playback) can’t access the desk. My phone and laptop which were connected initially can playback automatically. Quite frustrating and as the unit is less than 12 months old I’m tempted to ask for a refund.
