Hi all. I want to use QU 24 for broadcasting. Now I’m using mix 2 (mono sound), which goes into the matrix. from the matrix the sound goes to the sound card, and from it to the computer and immediately to the obs (there is no way to process it on the computer). Please advise what other ways can I broadcast? all possible methods
It is desirable that the sound be stereo. And if you take LR into the matrix, then the music that goes into the hall will end up on YouTube, this option is not suitable
Why not use one of the stereo mixes ? You don’t even need the matrix I think.
Giga
I heard about some “Alt out”. What it is? How do people stream in general? How?
You can use the USB B connection to digitally connect directly to a computer. The QU will shou up as a sound card device on the computer. In the IO patching setup is where you patch the to the needed tracks on the USB output.
Unless you have a dedicated live stream audio operator you will want that mix setup to be post fade and post all.
If your computer is a PC you will need to download the driver for the QU.
