It seems if I stream music via blue tooth from iPhone to CQ18T then CQ4YOU (on same iPhone) disconnects and won’t reconnect while BT is connected… Is that just how it is? Message is “Lib timed out” I’d be interested to hear from others experiencing the same or not. Work around is ST in… just trying to avoid cables ?
We have had reports of some devices which don’t like to be connected to the same thing via 2.4GHz WiFi and Bluetooth at the same time.
As described here - Bluetooth connectivity - Apple Community
Just as mentioned in that thread, Bluetooth runs in/across the 2.4GHz range so the first thing to try is simply switching the CQ WiFi to 5GHz.
This is also noted in the following article (which is more about the Bluetooth connection) - https://support.allen-heath.com/hc/en-gb/articles/20019096131601-Troubleshooting-Bluetooth-Connectivity
Hope this helps!
Keith
Thank you Keith - I’ll give the 5ghz a go ??
