BUG: Change Stereo to Mono Grp with FX Slot Insert
Can anyone confirm this Bug:
1) Route a Channel to a Stereo Group
2) Route this Stereo Group to L R
3) Insert in this Stereo Group a Desser or Dyn EQ
4) Pan of the channel should work as expec ted
5) Return the Pan of the channel to center posi tion
6) Change the Stereo Group to a Mono Group (via Setup → Mixer Config → Mix St ereo)
7) Main LR is getting some wired signals from the Grp. Left and right Signal are extremely diff erent!
FW: 1.6.1
Have you assigned and unassigned the Channels from the Group back to the L&R?
Yes, I can reproduce and confirm this bug.
Same FW or the latest FW?
Allen&Heath - I’m not able to understand you…. Selling FX Plugin’s for dollars, but not able to program things correct… World-class Mixingconsoles shouldn’t bring sutch problems…
The same.
I understand your frustration, and yes, it shouldn’t happen.
But in this case, it’s not related to an expensive Add-On; it seems to occur with every Plugin - and even with an “Empty Rack”!
I think this bug could be still a consequence of the change to the ability to switch inputs and mixes between stereo and mono without audio interruption (version 1.6.0).
A&H fulfilled this popular customer request, but unfortunately, they perhaps made this bug in the process.
Also with the latest FW 1.6.3 - Bug is still there!
Problem occurs also with an empty rack…
