There seems to be a minor bug in the editor version 1.42 on mac ( i did not check on windows)
I can assign 4 stereo matrix in range mode to output 1 thru 8. when i select output 1 my left channel on the matrix1 turn blue. when i select output 2 the right channel turns blue. This is correct for the 4 matrix channels. When i select matrix1 strip than output 1 and 2 are blue but when i select matrix2 strip then output 2 and 3 are blue instead of 3 and 4.
the same for matrix 3 and 4.
It’s a minor thing because it is just a wrong indication. the patching itself is ok.
thanks
Lieven
