Bug Report FX Insert Routs to Main R
Bug Report – FX Insert Routing Issue on Mono Channel
Subject: Right FX Channel Routed to Main Bus When Using FX Slot 5 on Mono Channel
Hello,
Today I encountered the following issue:
When inserting an effect on FX Slot 5 of a mono channel, the right FX channel is routed into the Main Bus, regardless of whether the insert is enabled or bypassed.
I tested the same setup using FX Slot 8, and the problem did not occur there.
Signal Flow
  • 8x gooseneck microphones → Group 1
  • Group 1 routed to Main Bus
  • Insert on Group 1:
    • Dante 62
    • Return signal on Input 15
Channel 40 Insert Path
  • Input Dante 62
    → Insert FX Slot
    → Direct Out Analog 4
    → DeFeedback AI
    → Return to Input 15
Observed Behavior
  • When using FX Slot 5, the right FX signal leaks into the Main Bus.
  • This happens even when the insert is bypassed or disabled.
  • Repeating the exact same setup with FX Slot 8 works correctly and does not produce the issue.
Please let me know if additional information or test files are needed.
Frimware 1.6.1 r4874
