[BUG REPORT] SQ PAFL Source changes silently when changing the Bus Configuration
So, found this yesterday, SQ6 1.6.1 r4874.
  • Set your PAFL to PostDelay/AMM
  • Go to Setup>MixerConfig>BusConfig
  • Make a change and Apply
  • PAFL a channel and try to Make an EQ change
You’ll notice now that the PAFL out is not following the eq changes.
  • Go to Setup>Audio>PAFL
You’ll notice that the PAFL Source is visibly still on Post Delay/AMM even tho the Source is audibly from the Preamp.
  • Change to Post Preamp then back to Post Delay/AMM to fix until reproducing again.
Hi @btrrah -
Sorry you’ve come across this - we’ve logged it and our R&D teams will investigate accordingly.
All the best,
