BUG RTA DISPLAY
The display of pink noise and white noise are inaccurate
Could you describe in more detail what the inaccuracy consists of?
Envoie un bruit rose sur le Master, la représentation sur l’écran de la courbe du bruit rose et fausse sur le RTA
Sends a pink noise on the Master, the representation on the screen of the pink noise curve and false on the RTA
Ah, now I understand what you might mean.
Perhaps someone from A&H could explain what kind of signal weighting is used in the RTA, or why the display differs from that when using an external RTA (maybe @Keith?).
eg…]()
Il devrait nous laisser possibilité de choisir le type de pondération, ou du moins afficher la pondération de base après c’est à vous de faire remonter l’information, c’est déjà assez compliqué de les contacter car d’ailleurs cette console a BEAUCOUP d’autres problèmes entre autres quand on l’allume ou quand on l’éteint, on a un gros (POC :flushed_face:) inacceptable
It should leave us the possibility to choose the type of weighting, or at least display the basic weighting after it’s up to you to raise the information, it’s already quite complicated to contact them because besides this console has MANY other problems among others when we turn it on or when we turn it off, we have a big (POC :flushed_face:) unacceptable
pink noise de cubase pro
The omission of periods at the end of sentences makes it more difficult for me, as someone who doesn’t speak English well, to translate.
As I said, I already understood your problem and agree with you.
I also hope A&H will clarify this, and if it turns out to be a bug, it could certainly be fixed with a firmware update.
The issue with the noises when switching on and off, however, was a hardware design decision made over eight years ago, which unfortunately cannot be fixed retrospectively with a firmware update or anything similar.
Try to submit a request here:
https://support.allen-heath.com/hc/en-gb/requests/new?ticket_form_id=360001516878
Je vous remercie d’avoir pris le temps de me répondre. Passez une bonne journée.
