I found a peculiar bug the other night using firmware version 1.5. I had set up a gang with the left and right main faders to link GEQ, PEQ, Compressor, Gate, etc. I left the fader position un-ganged.
Through the show I made a few tweaks to the graphic EQ in fader flip mode. Then at the end of the show, I zeroed the GEQ in fader flip mode by pressing the SEL buttons.
Shortly after I hit the fader flip button again and the Left channel GEQ was not zeroed. If I pressed the Right channel SEL button, then fader flip, it was Zeroed. I went back into the ganging section on the touch screen and confirmed that the gang was still there and that GEQ was included. It was.
I went back to fader flip mode, changed some things⦠then zeroed it. Exited fader flip, then went back in on the Left channel, and again, some EQ faders were not zeroed. Selected the right channel, fader flip, zeroed.
So I decided to delete the gang. Then I went back to each of the Left and Right GEQs and zeroed them. Then recreated the gang. Same thing, Left channel GEQ was not zeroed.
