Forgive me if this has been covered but after my initial testing it appears bus configuration is not stored in scenes…don’t get me wrong i am grateful for the the the stereo/mono saved in scenes but was hoping for busses as well.
thanks,
Andrew
Everything gets saved in a scene.
The recall is the point where you should investigate… I’m sure global recall filters prevent the recall.
It would be logical to block a feature that important for compatibility reasons.
thanks Steffan,
all global filters on “allow” and all safes off. I’m toggling between two scenes with the idea of changing bus configuration between scenes.At the moment bus configuration stays the same between scenes. I’m using the Bus config tab where rotary enables you to change between numbers of groups and Auxes.
thank you for clarification SQuser.
Oh yes, the stereo linking is saved, not the aux and group assignment. I did forget that.
