Hello.
My apologies if this has already been covered.
I’m looking into getting a fully expanded GLD system (ideally AR2412, 2x AR84s, GLD112 and Dante,) and now that the Editor software has come out I can get a better understanding of whether it will suit my needs. I’m confused when it comes to the specifications re the bus count and the mix output count.
Sorry if the following probably seems basic. I’m not intending to sound patronizing, I’m just spelling out my thought process so hopefully someone can tell me where I’ve gone wrong.
According to the specs the GLD can mix 48 inputs into 30 buses into 20 outputs. That sounds like more than enough IO for what I need; headroom is a good thing.
According to a thread I read once a “mix output” refers to “any master channel with full processing.” I understand the GLD has 20 of them, and includes mains, groups, auxes and mtxs.
The 30 available buses are a combination of the above master channels + the FX sends. Although the 8 FX sends count toward the available bus count, they don’t count towards the mix output count because they don’t have full processing. Instead of having eq and dynamics like the rest of the buses, they are instead routed straight to the internal FX processors.
My question is: how can I access the other 2 buses? If there’s 30 in total, a maximum of 20 can be the “master channels with full processing” and a maximum of 8 can be FX sends, then that’s only a total of 28; there are still 2 buses left over. All I can think of is that the other two buses are soloL and soloR. Is that correct, or am I missing something, or just failing at maths?
The configuration I set up to see if the desk would suit me is LR, 6x mono aux (though I only need 5 the GLD seems to want to do things in multiple of 2,) 4x stereo groups, and 2x stereo matrices. This totals 20 mix outputs. This should leave me with 10 buses. I can use 8 of them for FX sends (which don’t have full processing, therefore don’t count toward the 20 mix output limit.) That leaves me with 2 available buses. How can I access them? I can’t have any more FX sends because they’re limited to 8 (which seems sensible, given that there are only 8 fx processors,) and I can’t have any more aux/group/mtx/main because the 20 mix outputs are already occupied.
PS, In the above config (no connection to GLD; I don’t own one yet,) Editor shows that I have “6 buses remaining.” (Setup, Config, Mixer Config.) After some playing around, I’ve found that the number of matrices used doesn’t affect the available bus count, only the mix output count. You can have 10x stereo matrices, 0 mix outputs remaining, but still have 30 buses remaining. Is that normal?
Any illumination on the matter is greatly appreciated.
Thanks in advance.
