A friend has an SQ-6 that still passes audio to an Aux when the send to that Aux is set to -Inf. I thought that setting the send to Aux to -Inf should completely block the audio.
Firmware is 1.6.3
Tap is post preamp
Send is pre-fader
Observed using both local and Dante inputs.
Any thoughts on a setting or other cause of this behavior? Is this expected?
Are you 100% sure the user is adjusting the aux send level and not just the fader level for that channel? Setting the aux up as pre-fader would make the channel fader not affect the level of the channel heard in the aux mix. Obviously the aux send level of that channel should still affect the volume of the channel in the aux mix, but it could be the user thinks they are adjusting the aux send level, but is really only adjusting the channel fader level. This would easily explain why the audio is being heard in the aux mix.
I did confirm the correct mix was selected. I also tried adjusting the aux send level using the channels Routing screen. The first two people to complain were using SQ4You.
I think you confirmed this with your first sentence, but make sure the user has selected the proper aux buss in the SQ4You app. When our musicians mixed their own monitors using software, it was not uncommon for them to end up on the wrong aux buss and complain that their mix wasn’t working properly. The reality was that they were on the wrong monitor mix and were affecting someone else’s monitor mix!
Check your I/O that you dont have any other mixer channel patched to the same input socket - if so this input could be being sent to the aux buss separately from the expected channel.
