Button in custom control editor invertible
Hi all,
I would like to make a copy of the front panel inside the custom control app. Too bad the buttons are not able to invert like the physical buttons on the AHM32/64. Can this be improved? Than the same look/feel would be possible with virtual buttons in the control app (red-off or off-green)
Yes there is a work-around by making images, but this is taking a lot of time.
Regards,
Pascal
Yes, on the default button imagery we no longer let you swap images. That can certainly make it onto the feature request list.
However, if you go into Resource Manager and import any of the 7 Resource Packs or 5 Themes we’ve created, you’d be able to swap their images freely (to effectually create an inverse) without having to create any of your own.
Hope this helps!
