Je souhaiterais vous faire part d’un problème sur ma Allen Heath SQ6. La console Buzz sur tous les auxiliaires de sortie.
J’ai retiré tous les périphériques d’entrée pour être sure que ca ne viens pas de là. Elle continue de buzz meme lorsque les auxiliaires sont mutés. On dirai un problème de masse.
L’un d’entre vous a t’il déjà rencontré ce problème.
Bonjour,
il n’ya pas beaucoup de personnes ici, qui parle français, je pense. Ma français est la merde aussi, mais peut-être je peut faire une traduction.
I am trying to translate this, as there is probably not too many speaking french here?
“I am asking for help with a problem I am having with my SQ6. There is buzz on all auxiliary outputs. I have disconnected all inputs to exclude this as the source of the problem. But there is still buzz even though the auxiliary outputs are all muted. It could be a grounding problem.
Is there anyone having had the same problem”
As a answer and question from my side:
what is connected to the auxiliary outputs and is this equipment on the same power source then the SQ6?
Hi Jeroen
The buzz is on all aux outputs included the master but not in my headphones.
My set is simple MacBook Pro, SQ6 mixer, monitoring Yamaha.
I unplugged all inputs, the usb too and I tryed all the aux out one by one. When I mute the aux the buzz is always there.
I reset the mixer but it not resolved the problem.
I tried on other alimentation outlet too.
How do you identify this? With your Yamaha monitors? Could this be the problem?
I you can’t hear the buzz in the headphones while you listen to an aux bus it is possible that the noise gets introduced after the console…
monitoring and cables are not involved because I have already checked. . the buzz comes from all the auxiliaries. I think the headphone output is not on the same auxiliary circuit.
Can you describe the buzz in more detail. Is it white noise, or periodic, and is there any hum with the buzz?
Better if you can post a sample of the sound you hear. And tell us more about your entire environment and equipment.
Could there be any sort of feedback loop caused by mistaken settings?
Are you near a radio or TV transmitter, or airport using microwaves?
What sort of lights do you use? Are they on the same power circuit as the SQ?
Do you use any power conditioner or filters to remove noise from the power lines?
Are you feeding a PC from usb at the same time?
No. I doubt that…
how should this work?
Inside a virtual mixer?
There are no ground loops possible inside the desk…
The buzz is introduced to inputs or outputs together with other equipment.
So it could be introduced after the mute button of the mix out… but there is the DA converter and the socket… that’s it.
What happens if you don’t patch a socket? Is it still buzzing?
Odd question, but do you have a second console that you can connect to the auxes and main outs of the SQ? This could help to determine where the buzz comes from. Connect the outputs to the inputs of the second console and check whether you here the buzz as well on the second console (via your headphones, don’t use your monitors). I really doubt whether the buzz is caused by the SQ.
I’m going with a grounding/ground loop issue between the mixer and equipment connected to the aux out.
What type of connection are you using between the mixer and the connected equipment, is it balance all the way?
What type of audio input connector is on the connected equipment
How many aux outputs are you using?
Only connect equipment to one aux out at a time and see what happens.
Try disconnecting pin 1 one on the XLR cable connector at the equipment input that is connected to the mixer.
Non RS la console et les moniteurs ne sonts pas sur le meme circuit electrique. D’ailleurs j’ai branché la console sur d’autres prises electriques pour vois si le problème persistait. j’ai meme coupé les disjoncteurs inutilisés de mon tableau électrique pour voir si il y avais un lien.
