Bypass Preamp CQ12?
I have an ART mp/c tube preamp on order. I plan to use it with my acoustic guitar signal chain. Is there a way to bypass the preamp on the CQ12?
The block diagram tells no.
The preamp is necessary to adapt the signal to the AD converter.
But what are your concerns about connecting this device to your CQ and using it like any other audio source?
Thanks for the response. In the manual for the tube preamp it says this “Experiment with different input level settings for different textures.
In most cases the Tube MP/C offers superior performance to the on-board preamp on your console. To use the Tube MP/C instead of your on-board preamp, simply connect the output of the Tube MP/C to the line input of your mixer’s input channel.
Note: you can connect the XLR output jack of the Tube MP/C to the XLR input of your mixer, however most affordable mixers do not allow you to bypass their internal preamp when using the XLR jack. Use the Output switch and set it to the Inst. mode when connecting to a mic preamp. This will lower the output noise of the Tube MP/C and prevent overloading the input of the mic preamp.” Where it says simply connect to your line input to bypass the preamp, I assumed that was the best way to use this. But I noticed that when I plug a 1/4 into the combo jack i can’t bypass it. I just wanted to use the ART preamp the way they say it works best
Ah, now I understand more what you mean.
Your CQ also has a line input that doesn’t use a microphone preamp, namely the ST IN.
If you connect your device there in “line” mode and only use the L socket, it will be used in mono.
This way you can try out whether it really makes a difference whether you connect your preamp to ST or the jack input of a combo socket.
When comparing, set the adjustable input so that it is really as loud as the ST IN!
For a second comparison, use the XLR input again and switch your preamp to “instr.”.
I assume that the differences between all 3 variants, if the levels are identical, will be marginal.
Indeed it would be very interesting here to have your feedback about it.
If you are willing to, can you A/B test between line input and XLR input of the CQ and report here ?
When doing the comparison I would suggest not using the quick channel on the analog input but use complete and set everything ‘flat’.
Yes, of course, all processing elements (such as HP, Gate, PEQ, Comp) of the two channels to be compared must be deactivated or ineffective.
