I have contacted Cakewalk about this issue. Having had to write a more detailed description, I thought I would post it here as well… much the same, just some clarity…
Sorry if this is a duplicate… not sure who I should be contacting here…
I’ve been using the Allen and Heath QU-32 as my MIDI control surface in my studio for several years (32 fader strips, one super strip for EQ etc), I recently decided to try the latest version of Cakewalk by Bandlab. The platform seems very intuitive to me (being familiar with older versions) and overall it seems quite useable. I haven’t put it to the true test yet, in my studio, as I have not gotten past the issue explained below.
On the latest Bandlab edition of Cakewalk, I was able to easily use the “learn” function (right click on parameter you wish to control- remote control- move suface control-Learn-ok) to assign all of the faders and mute/select/PAFL buttons on the Custom Layer of my console to work with the channel strips in Cakewalk. No ACT Controller/Surface neccesay. Using the assignable controls in the ProChannl strip in Cakewalk, I also used this “learn” function to set all of the EQ knobs in the QU-32 Super Strip section for each channel. (i.e.- the LF Gain knob selected on the console controlled the LF Gain for the related track in Cakewalk)… THIS WAS GREAT!! and a function that I have not had before (the EQ for each was adjusted equally by using the console knobs!!!)….
Unfortunately, when I saved this Template in Cakewalk and came back to use it again, the EQ assignments did not seem to have saved…. the faders and buttons on the individual console channels work fine and are still linked properly, but the EQ knobs and HPF don’t work from the console at all…. I have tried many options (all of the different controller/surface options, a couple third party ideas, etc) and I have scoured forums. I believe this is a software issue, as I have tried assigning the QU-32 faders, which do save properly as fader controls, to be EQ controls instead… They work just as well, but still dont save…
To be clear, Cakewalk will properly learn the functions in the ProChannel EQ section (channel by channel), but will NOT recall them when the project or template is pulled back up… if this function is fixed I think it would add a lot of value to busy engineers, like myself, who would like to use a MIDI controller to run those functions *this is a lot more common these days with modern digital consoles having super strips capable of sending unique MIDI for each channel selected.
I’m assuming its an issue with Cakewalk as opposed to the console, because it learns it fine, but then forgets it when I close the session or save it as a template.
The QU-32 super strip has 17 rotars and 4 buttons that can be assigned independantly to 32 faders and the QU-32 will mimic the DAW precisely… x 32 thats over 400 controls that can be assigned, but get forgotten as soon as you save…
Thanks in advance for any help… Let me know if I can be of any more assistance in getting this figured out… Barring this issue, I am liking it so far.
