This feature request is call to A&H from the community, to update the firmware with the features suggested here for this product line.
This product has not had a major feature update since v1.10 in 2013 despite still being actively sold and marketed.
There has been some really great feature suggestions on here, and huge advancements in technology but the only updates we’ve seen for the last 13 years are bug fixes and keeping the system working with
Allen & Heath, we the community call on you to:
Update this product with new features as suggested, or communicate your intention and timeline to do so
or,
provide to this community a compelling reason why you won’t and why it’s still for sale?
The problem is, that they are highly overpriced and hardly anyone uses them I think. That leads to no dovelopement, which leads to no customers again. Also personal monitoring works great on Mixing Station, which cost almost zero.
You can’t really compare the two, because Mixing Station is just a remote control, while ME (e.g., -1) is practically a separate mixer.
In your dLive world with its many mix buses and remote connections, the difference might not be very noticeable, but with, for example, an SQ, you can quickly reach the limits of the monitor mix buses for more complex tasks.
So this gives you also with such consoles the option of providing very individual monitoring for many musicians.
But it’s a great system when you need a reliable and always identical monitoring setup on fixed stage positions. It depends on the situation if it is of any use. It’s definitely not the system for the average cover band.
Actually there is no official app for dLive that does monitoring well. MixPad has no aux limitation and 4You has a limit of 48 channels and you cannot assign auxes to users. You have to manually go to every users tab/mobile and log in as admin, assign an aux and login as non admin. Practically unuseable.
Mixing Station in monitor mode, send a layout to all users, done. Feature whise Mixing Station crushes any stock app to pieces.
This isn’t really related to the “ME”, but why on earth wouldn’t anyone do it?
If you’d just look here around a little more, you’d find plenty of people who do this - and even very willingly.
I love Mixing Station because, in stark contrast to A&H applications, it can be customized down to the last detail to suit your personal preferences and, in particular, the size of your screens.
Another big advantage is that Mixing Station runs on every major platform.
And you can generally use your own custom interface across different mixers, even those from other manufacturers.
But as is often the case, though, you have to put in the work and familiarize yourself with the Mixing Station philosophy and “programming”.
Thinking you’re getting something ready-made is the wrong approach.
Thank you for bringing this up. I love the ME-1 system and use it a lot in both my day job and church; I find it to be an almost perfect solution for church musicians. That said, it would greatly benefit from some attention!
The CustomControl app is great, but it isn’t something a person can just open and start using for monitor mixing immediately. It takes a LOT of time and effort to build out a CC system that has the ability to mix monitors well. I’ve personally created a CC monitor mixing interface and it was a huge undertaking honestly. The payoff can be great, but it only works well if the designer/creator programmed it well. In typical programming speak, “Garbage in - garbage out”.
I think the main issue is communication as much as the missing features. If the product is still being sold, its reasonable for users to expect some indication of what kind of development or support is planned. Even if A&H doesn’t intend to add the requested features, explaining why would be better than leaving users guessing. Some of these older products are still perfectly usable, but a few meaningful updates could extend their useful life quite a bit.
