Can a dLive mix rack be used with-out the Surface just using Ipads' or Mixpad
Is this possible?
Feasible?
For someone wanting to get into the dLive C class.
yes as long as you have WIFI and a iPad or Laptop…
After lots of reading it seems you can not just use an iPad with dPad to do complete mixing. There are restrictions. You also must use the Mix Pad as well if you do not want to use a dLive surface.
Which brought me to the TCP Midi driver.
I notice on the downloads the driver appears to be the same as the QU/GLD driver from last year installed on all of my Macs.
How ever it has an ever so slightly different name with the word dLive added to it.
Can anyone confirm if it is the same driver or do I need to add this new driver to my Macs?
OR can / could I just use the dLive TCP driver for all 3 QU GLD and dLive.
I’m talking about the TCP midi driver.
Sorry that was meant to say you need to use dLive Director and iPad MixPad.
However my question is still the same…
The TCP MIDI driver is the same (not to be confused with the DAW Control driver), and the protocol is very similar to GLD.
