Still kind of new to SQ. We just bought an SQ6 with 2x AB168 Snakes and 4x ME1’s. I plan to use the built-in SLink part on the mixer to connect our two-stage boxes. But because of our stage and flexibility. We don’t want to connect our ME’s to the end of those snakes. We want a separate cat5 run from the board. I included a Slink card in the purchase to use to give data to our ME’s. The only problem is I kind of didn’t really research it and assumed it would work. Now it’s 1:30am and I am spinning in circles trying to figure out if that card will support ours ME’s. I think yes because it’s an Slink port.
BUT HERE IS MY MAIN QUESTION: I noticed the I/O Patch has a “ME” Tab but at the same time, It also has a “I/O Port” Slot.
Which tab would I use to configure the ME’s?
How does the “ME” tab know where the ME’s are plugged into if that makes any sense.
Thanks! (I also included a very simple image of the setup)
From the reference guide:
“ME-U, ME-1 and ME-500 units use the dSnake protocol, so can either be connected directly, or connected to the monitor or expander ports of an AR2412 or AB168.
The ME patching is applied to any SLink port that is running the dSnake protocol, which could be the SLink port, an SLink option card, or both at the same time.
The ‘SLink’ and/or‘I/O Port’ text on the ‘ME’ tab are displayed in white when patching is active on either port.”
But in short, the setup should definitely work, and you only need to patch any signals you want to use on the ME system using the ME tab.
If you’re still running into issues though, you can always contact us directly using support.allen-heath.com.
Bumping this thread as I’m researching the ME-1 for our MD.
We have an SQ6 and 1x DX168 on stage.
Did I read correctly that the ME-1 cannot be connected to the 2nd DX168 port?
Txs.
that is sadly correct. The ME units work at 48kHz and your DX168 is a 96kHz device. Cheapest solution: IIRC, You could purchase an optional SLINK Card and connect your ME-1 to it. More expansive: AB168, AR2412 and the GX4816 (which is also 96kHz, but has a dedicated ME output) are the stageboxes that can be directly connected to ME units.
– Do you need to switch the card to 48kHz?
No. The system will automatically make any adjustments needed.
– Will names automatically transfer?
Generally yes, but not if you use a unsupported device (like a general network POE switch).
– Will it work with a PoE switch? That’s what we currently do with our dLive.
This is unsupported, but with the right switch/settings it can work. Obviously you can simply move/duplicate the “working” system from the DLive and it should continue to work with the SQ. You experience using the SQ should match your experience with the DLive with regard to the ME system.
