Can I use Stereo Mix as sub group?
I just bought A&H Qu-16 and found that it does not have sub groups. I want to control my drum level using just 1 fader.
Can I send all drum mics to a stereo mix out (Mix 9-10) and then send the stereo mix to Left/Right? If it’s possible, please teach me how to do that.
Bobby
Not yet. There are a few threads on the forums about it. As close as you can get is to set up the mix as post fade, with the channel sends at unity (un-assign the channels from LR.). Then route the output of the mix to a pair of spare inputs, and route those inputs to LR. Of course there’s increased latency, and you have to have the spare inputs available, but it’s as close as we can get ATM.
Thank you much for the tips
and you could use one of the stereo returns for the inputs back into the console, this wouldn’t waste any of your 16 inputs.
You would need a pair of cables (for stereo) with XLR female on one end, and a tip-ring-sleeve 1/4" on the other.
Got it. Thanks
