Can PEQ HF and LF "mode" be set using SQ MixPad app?
Have just started looking at using MixPad to operate the desk from the body of the church. I can’t seem to change the Mode settings for the LF and HF PEQ using the app. Is there a way to do that? I notice a feature request along related lines here: MixPad PEQ - Press and Hold to set parameters
I’m referring to:
LF Mode = Shelf, Bell, HPF
HF Mode = Shelf, Bell, LPF
Thanks, David
In the middle of the “normal” view there is an “up/down” Arrow symbol.
Drag it down to see details. In PEQ view you can adjust the LF and HF type then.
Tom
@wheeled
Perhaps one more tip for (you as) MixPad beginner:
Simply use the funktion “?” = “HELP” under MixPad.
There you will find not only a description of this “Screen split” function you needed, but also of all other functions along with some further helpful tips.
Thank you folks - I will check it out.
