Can QU do multitrack recording of the mix outputs?
Hi folks,
I’m a bit confused, I have been trying to do multitrack recording of the QU-16 but all I want to do is record all the mix outputs and the LR output. I have tried and I’m just getting the individual input channels-I think post fader.
Is that possible to record only mix outs?
User manual > I/O Patch Setup-USB Audio
Thanks. I’m seeing my problem. I thought I had set that USB Audio routing correctly, but as scenes change, that routing is going back to the default. I have to dig in to just figure out how to keep that from changing. Probably some “safes” thing. Thanks again.
ok-I got it sorted. I had to turn on Output Patch->Block on Global Filters after setting the routing the way I needed it to be. Now scene changes will not reset the routing.
