I’m in a situation where I need a very small flypack WITHOUT wi-fi. Can QU-SB or QU-PAC be hardwired to MAC or iPad? MAC would be preferable. Thanks!
With an iPad and a lighting or USB C to ethernet adapter you can.
Thanks for the post. Bummed about no mac app.
I have installed BLUESTACKS and run Mixing Station for Android on my Macbook.
Interesting Hoody. I will look into Bluestacks.
Is this something you have done, or just theorised about? I did this but it didn’t work. When I tried to get into the Qu_pac with Qu-Pad it threw up a “Couldn’t connect” error.
Did you have a router connected to the QU Pac and then connect the iPad to the another port on the router?
Hi Mike,
Thanks for the contact…
I’ve a Lightning iPad to Ethernet adapter gizmo. (I don’t know the right term for the iPad’s physical interface port.)
The CAT-5 plugs into the Qu-Pac like you would with a (wi-fi) router.
It will connect after a short while and allow me to see the Qu-Pac.
Fire, up Qu-Pad, select User:=Admin, it has a go but kicks up an error. Sorry to be a little slack, I didn’t write the message down, but I think it was a Failure to Connect.
I looked at the iPad’s Ethernet info and it appeared to be what the Qu-Pac said it was. Admittedly my datacomms knowledge is not great.
Grateful for your help, jb.
