We have an SQ7 in a church setting. I was not in on the setup, but have inherited the operating of it. There is a monitor amp connected to the Aux1 output, which is channeled through the S-Link. It is used only for special music involving tracks and soloists or duets at times. At this time I have to go to the speakers to check on balance. Is there a way to send the Aux1 output to the headphones as well as the S-Link?
Just switch to Aux 1 with the buttons down the right hand side, and hit the pafl button above the main fader.
Also,
if you leave the PAFL button on (above the mail out fader) , you caan go through all the aux’s and the headphones will give you that aux, when you go back to L/R the headphones will hear the L\R mix
if you leave the PAFL button on (above the mail out fader) , you caan go through all the aux’s and the headphones will give you that aux,, when you go back to L/R the headphones will hear the L\R mix
If you want to you can turn off the follow mix option in the PAFL set up menu so after selecting PAFL on Mix 1 it will stay with with Mix 1 regardless of any other mix selection until you manually select PAFL on another mix or channel.
