Case Dimensions
Is there a document I can send to a case manufacturer with the profile dimensions of the MEI?
Similar to the mixer dimensions you have for larger mixers for case manufacturing purposes.
Regards
Toby
Suggestion. Lots of sources for attaché style aluminum cases with full foam blocked so you can create your own cutout size. We use them for all kinds of small gear. Another type is pistol cases. They come in plastic and aluminum. Get them at any gun store. That us if you are in USA.
George.
Mid-America Communications A/V.
Suggestion. Lots of sources for attaché style aluminum cases with full foam blocked so you can create your own cutout size. We use them for all kinds of small gear. Another type is pistol cases. They come in plastic and aluminum. Get them at any gun store. That is if you are in USA.
George.
