Case for multiple me1
Which cases (peli, Nanuk, skb) are people using for transporting their me-1’s
I have 4 and would like to put them in case for transport. Custom build is possible, but maybe there are good suggestions. Preferable for 4 or 5 in 1 case. Including some extra stuff. Adapter, cable. ……
Thanks for the input.
Look at the Pelican or style there of cases that have the diced foam inserts you can pluck out to fit what you need.
Look around for a generic case that can be re used and buy the foam and cut to fit.
An electric meat carving or bread knife with the two blades cuts case foam perfect.
Swanflight in the UK do a flightcase that can hold 6 units and it has additional storage space. Not super cheap, but their quality is spot on and they ship globally
https://www.swanflight.com/allen-heath-me1-mixer-flightcase-holds-6.html
Thanks all for the input.
Have a nice 2023 :slight_smile:
A little late to this thread but like you I have 4 x ME-1 panels and I travel them with their accessories, 10/15 metre Ethercon cables and a Presonus AVB PoE switch in one of these:
This is my way…take my old Peli-Case and cut thick foam for inside. Hold it fine and Peli is Peli as know and no more comment need… :wink:
Are those aftermarket mic mounts in the back? If so, do you mind sharing info?
Hello, can I ask where you got the foam from please? Thanks
This is mine!
This is the best one I’ve seen! Can you please share a link to the case? Also any instruction on how you got the foam and cut it to fit would be greatly appreciated.
The foam was cut using cnc machine with hard foam. You can find case with the specs above. I also included a drawing of interfaces. You can measure the ME-1 and draw the same as attached file.
Thank you so much! This is an excellent design
You are very welcome! The ME1 is very solid device. Never failed me on big show ( I do shows with 40-50k audience scale). Aviom did failed me a few times.
