Cat 6
Hi all,
is there any reason NOT to go for Cat 6 between my Qu-SB and future AB2412 ?
Reason: I think I’m gonna need one or two so-called “feed-through” connectors and the only ones I can find clearly state they are only suited for Cat 6.
Thanks !
Giga
How long is the total length?
The CAT6 feed through should work fine as it is built to higher spec than CAT5e.
I have a CAT6 coupler that I have used on standard CAT5e for ethernet.
Ah, maybe 20 to 25 mtrs at the most. So Cat6 it’s going to be, thanks Mike !
Giga
