I’d love to see a log on how often a network connection to stageboxes was established since the board was switched on. would help to see if the cat connection is stable.
Hi Gab,
Unfortunately, there are no logs on SQ as it doesn’t have a real time clock. However, we aren’t aware of any connection issues with stage boxes on the latest firmware (1.2).
Alex
I’d never thought that this day and age a mixer could come without a clock… Before I buy an SQ, please tell me what other standard harware features you omitted to save money, so I can invest properly.
thx alexs! i wasnt suggesting that its a general problem with sq. when i travel around with bands we often come into venues where there is an existing cat cable from foh to stage already, but i never know if their cables work properly. id just love to see if there were any dropouts so that i can see if i should use my own cabling ( which of course i would like to avoid; more work and hard to get out if theres a dj after the bands and people are still there etc). some simple warning that there was an interruption in the connection would suffice. i use to set up the mixer and stagebox before the band, and while doing the bandmicing i could see if there where any problems with the network.
Jens… feel free to buy a different mixer…
all your standard features are available on other devices…
hmm, nice answer in a manucafturer forum to suggest to switch to another “Marktbegleiter”
But back to topic. It would be anyway a good feature to have some monitoring on error states like problems with the sync to the stageboxes. And if there is the possibility to reset that counters individually this would be the cherry on the top.
Steffen R.: Thanks for your advice. You can keep using gear that won’t tell you where the problems are and where basic features are missing without even an acknowledgement by the manufacturer THAT they are missing and will come without even thinking about saying something about it.
And of course it’s absolutely no doublestandard that have a biiiig list of things you want on the dLive, but criticism by others on A&H products, that’s a no go. Got it, thanks again!
