We are going to be installing a ME1 system at my church and will be running new cat cable to the stage pockets. Is regular UTP cat5e ok or do I need to use shielded (STP) cat5e? If STP cat5e is needed I would guess that would also apply to the cable that would go from the stage pocket to the ME1 mixer. I would like to get some of the more rugged and flexible cables to go from the mixer to the stage pocket but I’m not seeing a ton of options if shielding is needed.
Hi Davet112
In most regions, for compliance with electromagnetic emissions regulations, you should use shielded cable. As a result, this is the only type of cable that we can recommend that you use.
Hope this helps
- Jeff, A&H
My main runs from FOH to stage are all Cat5e STP as recommended but I believe all our on stage cables are regular Cat5 patch cables that we had from our old Aviom system and we have no problems.
