I know there has been discussion before regarding cable lengths but all I found was for 5e. Maybe I didn’t dig deep enough. I have an installation with QU32/AB168 coming up. Large auditorium. Long distance from control room to stage. Having to use existing large conduits. Looks on paper like run could well exceed 300’ maybe pushing 400’with stage reel.
What I have always gone by is the 100-120m protocol. But will 6 gain you more distance? It does in other things I’ve done like HDMI extenders.
The ~100m number is a limitation for copper ethernet (physical delay running a bit from sender to receiver) for proper packet collision detection, using Cat6 does not change this.
However, the native dSnake connection is full duplex and does not need to handle collisions at all, so maybe longer distances are possible. This highly depends on electrical losses through the cable and design of transmitter and receiver circuits.
However, I personally won’t push the spec four times and either go for fiber or add some switches as repeaters.
I guess Bob will chime in soon…
I THINK (need to go and check) that Cat6 is shorter limits than cat5 due to more twisting…
Back in a mo - interesting question
Nope - they are all the same, must be something else I can’t recall which is a more twisted pair (and therefore the cable length is longer per “ground metre”
100 metres is the limit between active nodes - so if you are out past 300’ I’d bung a simple ethernet switch in the middle.
If you want WiFi access as well then either read up on vlans or use a second cable
I read in one location (and now I’ve lost it, although it’s alluded to above) that the limit was due to the signalling speed, and the requirement not to have a whole packet ‘on the wire’ at one time. I suspect that might only have ever been an issue in collision domains though. I do know that I have run >100m 10Mb/s over crudely patched* Cat3 - but that was switched at one end.
The ends went into old telephone connectors - a 2" long PCB with four traces which plugged into a socket. So that lot was all completely untwisted :o
Personally…
I’d use it as an opportunity to get a set of three VLAN switches (one at each end to handle dSnake/Control, the other as a spare/extender).
Obviously they are billable…
The Ethernet limit for utp (unshielded twisted pair) is 100m no matter which cable you choose. That is 328 feet. Go over the limit and you will see issues.
The Category of the wire impacts the speed it can handle. Cat 5 and 5a can handle 10, 100, 1000Mbps. Cat6 can go higher…sort of, and has better noise/interference immunity at the slower speeds.
If you need 400 feet then add an active device, such as a switch, as was suggested above. Another option would be to use fibre optic cable, but that will require a media converter or switch on each end. It will certainly exceed your 400 foot requirement.
Yeah. Was afraid of that. I recently had to replace a 5e run with 6 to solve and HDMI extender issue so wasn’t sure it was a distance or bandwidth issue. Putting 6 in fixed it.
This is a large room. The conduit route is just long. I don’t have much choice. What we ran is shielded CAT 6 but as mentioned I think I’m going to be at 350ish maybe.
Not sure where I can insert a switch that I can get power. Maybe near the end of the 300’ leg. Then rest is 100’Jackreel with Ethercons. I can and was planning on shortening it. That only really need about 50’ to hit the AB168.
In one post Nicola said max 120m but recommended 100. If it would work to 120m I can do it.
HDMI extenders are rarely ethernet, and the reduction in crosstalk of cat6 may well be enough to go way beyond 100m with that kind of device.
It is highly likely to work to 120m - I can’t actually find any definitive document talking about the logic behind the limit - and collision detection is frequently mentioned (either true or just self reinforcing, I can’t tell). IF the 100m is about collision detection then you have no issue. Also note that dSnake is a 100Mb/s protocol, and Cat6 will take Gb/s to 100m. Signal degradation should be different between the data rates, so that supports the collision domain theory.
Any PoE switches available? Or is that getting a bit fancy for the desired application?
A simple 30-40m mains reel would probably work quite well to get power down the conduit, although it’s not ideal (since the sockets tend to be on the reel…
The protocol is the electrical bit - the physical cable can be used for all sorts…
I’m kind of hoping we get cat5 wiring for lighting circuits - after all 25W of LED with built in data connectivity could be rather useful.
Yeah. Was afraid of that. I recently had to replace a 5e run with 6 to solve and HDMI extender issue so wasn't sure it was a distance or bandwidth issue. Putting 6 in fixed it.
Nicola?
At 350+ you will likely see errors and retransmissions which is not good for real time data from an AB168.
Replace the long Ethercon with a basic 50’ utp jumper to keep it under 300’. Replacing broken jumper (without Ethercon connectors) as required is better than packet loss in an audio system.
Cable length only affects signal quality in our dSnake scenario. The difference is pure physical, in terms of TP symmetry, capacitiy between wires, resistance. A better cable may provide larger lengths in terms of capacitance (like Cat6 over Cat5), but the resistive parameter is fixed. So you will get a drop in signal amplitude on longer cable runs which is known in our world as Signal to Noise ratio (SN). It is up to the receiver circuit (including the PHY) to handle this (all industry standard components, no big choice there).
Depending on your environment longer runs using a better cable may work, but reduced SN opens the doors to fail on smaller electrical influences.
I’d probably just try it (using a shielded Cat6 or even Cat7 cable). If it does not work reliably, splice the cable wherever a switch could be easily mounted.
Its going to be a couple weeks or more before I test this. Just started on this install. Haven’t ordered the QU32/AB168 yet. Mon we continue on our quest to get the wire through a maze of concrete block walls and conduit to its destination. I think there is a point above a dressing room I can insert a switch if I have to. Not sure about power there. There is a chance I might be able to re route it through a mechanical room and shorten the run. Not use the empty conduit we were planning on. If that works I maybe can shorten it by 20-30’ or so. Anything at this point would help.
I will report back on this when we get it going. Might wind up being last week of June. Thanks for all your input.
Well Allen & Heath sell a 100m cable, so that’s 330 feet (almost)
WHat Nicola said was:
"120m is the max allowed length of each dSNAKE connection, not the total run of the chain. However this is dependent on cable quality and external interference. Not all cables are guaranteed to work at 120m. Rule of thumb is stay within 100m to avoid pushing the limits (which might result in occasional QoS errors). So for example you can go 100m into the AR2412, then another 100m into the AB168 / AR84."
If I get a chance I’ll join my twin 50m CAT5 drum up to itself with a another long bit I’ve got and do a test for you. Probably not until next week though.
Mark. That would be great. It will be a couple weeks before I can unless I take my QU16/AR2412 up there and test it. Still more than a week before I can do that.
