CDM32 and SQ5
Hi everybody,
I recently joined the A&H ecosystem with the purchase of an SQ5 and two dx168. For most of my work, the SQ5 will do just fine, but now I just got an incredible offer for a used CDM32, which I’m thinking about taking. Now with only the CDM32, I’d need at least a C1500 or some other Fader controller to go with it (Ipad is not my preferred way of working, I need faders in my hand). Since I wouldn’t need the CDM32 that often, maybe 10x a year for some bigger jobs, I can’t justify the price for a C1500 or a high-quality fader controller to go along with it. So my question is:
Can I use the SQ5 as a fader controller for the CDM32? So this would mean I would run dLive director on my laptop and control most of CDM32 with that (eq’s, dynamics, fx, etc. etc.) and then somehow hook the SQ5 up as a controller as well and only control the CDM32’s fader with the SQ5. Is that possible? I know I can’t use the SQ5’s processing in this scenario, but is such a setup generally possible? And if yes, how exactly would I hook such a system up? CDM32 on stage and from there? How would I connect the SQ5?
Thanks for your help!
no it’s not possible at this time…
Pitty…
Can some mod then please move this in the SQ or dlive feature suggestion forum? :wink:
To help my purchase decision: can anyone from A&H comment on wether this might happen or is even in the pipeline already, or if this is not possible and I should not hope for this to be possible in the future?
you should not hope for it
the communication protocols are quite a bit different
and this will not be possible in the near future
and the Director has no fader remote capability at the moment
and I doubt that this will change
and A&H will not confirm any of their planned features until it is released… never (nearly)
on the other hand, the CDM32 is a full featured mixer without hardware UI
add a PC or MAC and you have all the power from the dLive
Are there any resources on how I could build my own fader wing without using the IP8? My dream setup would be a Microsoft surface with director running and something like the Behringer x-touch compact or even the new waves controller “Fit”. I just think the IP8 (or two of them if you want to go 16 faders) is waaay overpriced. I mean the waves Fit is half the price of two IP8’s and gives you arguably more. Any experiences with other fader banks than the IP8?
the IP-8 connect directly to the dLive (and the AHM64) so they are not comparable with other controllers
and as mentioned above, director has no remote control support at the moment
you can use every controller that sends MIDI over TCP/IP to control the dLive directly
