CH to ALL Mix
I think this is the last thing on my new SQ6 that I can’t wrap my head around. Is there a YouTube video or some detailed written instructions for using the CH to All Mix and Pre/Assign buttons? I am gonna wear these buttons out trying to get some sense of how I can use them in a predictable manner. I know! “Digital panel newbie.” Help an old guy please. :slight_smile:
Doug
Hi Doug,
These are all momentary keys, so need to be held down and used with other things to affect routing.
Holding CH to All Mix shows all the sends for the currently selected channel across the fader strips. It’s the fastest way to send a single channel to multiple mixes.
Holding Assign and using the Sel keys, you can quickly assign or unassign channels from the currently selected mix.
Holding Pre and using the Sel keys you can select whether channel sends to the currently selected mix are pre or post fade.
As these are all to do with routing/sends, I would recommend looking at the mix sends in a routing page whilst having a play with these keys to see what you’re affecting.
Hope this helps!
Cheers,
Keith
OK - as we’re on the subject, I’ll repeat my future request!
CH to All Mix is very useful. Can it be added to the footswitch options please, so that I can use both hands?
Thanks.
Hi Mark,
It’s on the list :wink:
The only danger with this is when using a latching switch, as there would be no indication on the surface that you are in this mode and not just on a layer with mixes.
Cheers!
Keith
Thanks Keith.
I’ve made myself a double footswitch which is non latching*, but I do see how it could be a problem.
*Really must get around to putting an LED on it though, so that I can quickly locate it in dark venues!
Thanks Keith. I’ll give this a try.
Best,
Doug
Great explanation, Keith. I now understand that part of my SQ6. Thanks.
Now a +1 for a foot-switch setting for CH to All Mix. In a hurry, two hands on faders would be, well, twice as fast as one hand. Looked through all the foot-switch possibilities and that would be the one that I would use in my typical situation.
Doug
@Keith +1 for this latching feature. I frequently need both hands to adjust a channel in multiple mixes. Maybe have the select buttons or something flash while in the “ch to all Mix” mode?
Reason I’m replying here now, I was about to create a feature request for this very thing.
