Is it possible to change all of the channels that send to a chosen Aux. to pre-fade? They are always set to post-fade which can be a pain sometimes (unless there is an easy way to change them all). I have just changed from LCR plus to LCR sub and it has reset everything to post-fade. Again, a bit of a pain.
Changing the bus configuration resets all DSP mix parameters. Before you do this save your current settings to a Scene using ‘Store All’. After changing the config simply Recall the Scene and your mix settings including Pre/Post settings will be restored.
