I have some questions …
- Is it possible to change the order of the various processors in the channel strip? For example, put the equalizer after the compressor?
- Is it possible to change the “gate” dynamic processor in a “compressor”, in order to have two compressors on the same channel? It would be very useful for example on singers to be able to use one as “de-esser” and the other as a real compressor.
- Is it possible to select the point from which the “Direct Output” signal is taken?
- I would like to use a GROUP to create a second “Master Bus” with a volume independent of the main Master Bus. It’s possible to do it?
- Is there a way to create an HPF & LPF filter on the output buses?
Thank you all.
D.
