Hi there
Is there a way to change the speed of the channel rotary encoders for gain, pan etc? Sometimes I wish for a smaller resolution.
Many thanks!
Hi there
Many thanks!
Hello!
To adjust the speed or resolution of the channel rotary encoders for functions like gain and pan, you’ll typically find this setting in your device or software preferences. Look for a section related to control surface or hardware settings. There, you should be able to fine-tune the sensitivity or resolution of the rotary encoders to better suit your preferences. If you’re using specific audio software or hardware, referring to the user manual can provide step-by-step guidance on making these adjustments.
Hope this helps!
Regards
Do not want to offend anyone, but can these bots be turned off?
